- On the directional pad on the phone press the center button
- Press 5, or use the direction buttons to select Preferences
- Press the center button on the directional pad again
- Press the down key twice to select Sounds
- Press the center key or Select soft key
- Verify that the ring tone is not set to “silent” and the ring volume is higher than 0
